guys can anybody tell me how ro reset the t belt warning light after changing the cam belt on the 3L turbo intercooler KZN185 model (1996)
technical help needed to reset cam belt warning light
It involves taking the dash clocks out I'm affraid, then you just remove a small screw from the rear of the speedo and re-insert it into the adjacent hole.
http://www.hiluxsurf.eu/faq_interior.htm#timing_beltLast edited by BUSHWHACKER; 2 October 2006, 13:24.
yer trouble is it dosant always work soposed to do it says `so in the book but many times i have endid up with me speedo in bits mentions that the small cog with numbers on has to be in the corect position try geting it in the right position lol is it no 9 canot rimember of the top of my head ??
yes maybe your right vince lol was trying to say swaping the screws dosant always work ` and somthing about that numberd cog at the back of the tumblers ` when the speedo is in bits not got me book to look it up
dose that sound any beter ???
Originally posted by mrsurfyes maybe your right vince lol was trying to say swaping the screws dosant always work ` and somthing about that numberd cog at the back of the tumblers ` when the speedo is in bits not got me book to look it up
Yep, that made prefect sense. So what your saying is that if you use three hinges instead of two, it will prevent the fish fingers burning after the birds have gone to Nova Scotia for the Winter!
if you change the belt before the 100,000klm this is what your soposed to do
