right autolink have sent me new discs for my 96 surf how easy are they to fit. do you have to remove the bearing or do they slide over as normal thanks mark
discs
You have ot remove the Whole Rotor i would imagine, if its the same as mine. Then unbolt the old one which may be hard work and then bolt on the new one.
Hope that helped a bit!
Derek
1990 Hilux Surf SSR Ltd
Originally posted by slydogwell il take it apart tomorrow and have a look cheers lads
Its not to bad a job (apparently) yes cone washers need to be removed
and a larger hammer to get the lug bolts out to seperate the disc from
the hub.Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
