Hi all new to the forum, just bought a 96 30 td, I want to give it an oil change, what oil do I use synthetic, semi synthetic or diesel turbo oil, very pleased with my buy so far, thanks mayto
what oil in 30 td
Don't bother...
With flushing oil you are really wasting time, all good modern oils do the best job they can by holding the dirt in suspension so that the filter can deal with the nasty stuff. If you go from a mineral oil to a semi/fully synthetic oil you will only need to drain the old oil from hot...take care not to scald yourself when draining....allow a goodly drain time say 20 mins or so and then re fit the sump plug with preferably a new sump plug washer/seal. Change the filter ....watch for the spill off tube as it dumps oil under the left front side of the engine bay....fill with your chosen oil (I use Castrol GTD Magnatec) and if its a fully synthetic then you don't need to change it so often; but consider a filter change and top-up....fully synthetic was originally designed to never need changing as it doesn't break down like mineral oil....they dropped a *ollock here because that reduced oil sales, so now they just tell you to change it as for normal oil...which of course fully syn isn't.
If you really must use a flushing oil don't run the engine too long it won't do it any good. The high loads generated in a diesel especially on the crankshaft journals and the dubious load bearing qualities of flushing oil could well do more harm than good.
