help please what have I drained
  • help please what have I drained
    Help please. have drained the case where the rear prop shaft meets it at high
    level and the front prop shaft meets it at low level.The fluid that came out
    was red dextron type fluid(not 75-90 diff oil.)Is this the transfer case or the transmission? .It seems straight foward enough to replace just need to know
    what fluid or oil if it was originally incorrect.Have looked at stickeys oil and
    lube diagram but its not clear enough to tell what this is.A diagram of the drive train would be perfect.Any help at all would be appreciated.
    The auto transmission fluid is red Dextron.
    Lots of info here to help you out...
    http://www.toyotasurf.asn.au/techsite/downloads.htm
      Sounds like the transfer case to me, but i know nothing.
      =SOLD UP!=
