Water Pump Change
  • Water Pump Change
    Last week I flushed and refilled the cooling system. Today noticed a drip when I stopped. Appears to be coming from behind the bottom pulley. Water pump?, only leaks with engine running. How big a job is it on a 3.0L. Can't find a thread that tells/shows how. I've done the viscous fan so I know how to get that off. Any help appreciated.
    [COLOR=DarkOrange]ONLY STUPID PEOPLE THINK
    hi there
    its not that bad a little fiddly you have to remove viscouse fan and all belts not timing 6 bolts a little tap with hammer n your done you can remove pully from water pump if you want just a little easier to see
    tip slacken pully bolts while belts are still on makes cracking bolt on pully easier
      Originally posted by abentham
      hi there
      Thanks for the info, will order a pump from Milners tomorrow
        i have a spare water pump if your interested £40 + postage or depending on where you are can deliver or collect but before you go down that road are you sure its the water pump n not just the gasket ?
          I suppose the only way to find out is to strip it down ? If it is the pump, @ £40 I'm interested
            Took all the bits off this morning, definitely pump leaking from tell tale. My super generous father-in-law took me to milners to get one,( 2 hr round trip) and he paid for it £88. ( BTW many thanks for your offer abentham, if it had been my money it would have been £40, but he insisted, I wonder if its because I'm taking him fishing tomorrow. ) Truck was back on the road by 3pm. The belt tip worked a treat.
              hi there glad to hear you have her running again
              no probs on the water pump
              glad i could be of some assistance
              have a good day fishing id have to use one of these to catch anthing
              lol
              happy trukin
