Last week I flushed and refilled the cooling system. Today noticed a drip when I stopped. Appears to be coming from behind the bottom pulley. Water pump?, only leaks with engine running. How big a job is it on a 3.0L. Can't find a thread that tells/shows how. I've done the viscous fan so I know how to get that off. Any help appreciated.
Water Pump Change
hi there
its not that bad a little fiddly you have to remove viscouse fan and all belts not timing 6 bolts a little tap with hammer n your done you can remove pully from water pump if you want just a little easier to see
tip slacken pully bolts while belts are still on makes cracking bolt on pully easier
Thanks for the info, will order a pump from Milners tomorrowOriginally posted by abenthamhi there
[COLOR=DarkOrange]ONLY STUPID PEOPLE THINK
Took all the bits off this morning, definitely pump leaking from tell tale. My super generous father-in-law took me to milners to get one,( 2 hr round trip) and he paid for it £88. ( BTW many thanks for your offer abentham, if it had been my money it would have been £40, but he insisted, I wonder if its because I'm taking him fishing tomorrow. ) Truck was back on the road by 3pm. The belt tip worked a treat.
to catch anthing
