Hello I am new member and I had introduced myself in my first post but here I am again with some other minor concerns about my baby: a 98 hilux surf.
I have the following concerns:
1) Leaking Oil Pan
One mechanic that I consulted said that in the hilux surf you have to remove the whole engine to fix a leaking oil pan. Is this true?
2)Leak from where the transmission couples with the engine( i believe its the crankshaft)might be wrong on that one.
How can I fix that leak?
3)Exhaust manifold has oil on it because of leak from engine breather hose I believe. Not sure if that hose is a breather hose.But it is a hose that comes from the top of the engine.This is a effect of the problem that i had stated on my first post.
How can I fix that?
Thank you for your time
Have a great day dreaming with hilux surfs and 4runners.
Jorge from Nicaragua.
1) Leaking Oil Pan
How can I fix that?
