I've noticed a worrying thing with the old girl the last couple of days.
Since this hot weather started, in the morning when it's cooler everything is fine. But on the journey home, I seem to be having problems keeping the oil pressure up. When stuck in traffic, the oil pres gauge is way way down the low end. Even at 2500 RPM on the motorway it only rises to about 1/3, and then it seems to be struggling to reach that point.
In cool weather, this monring for example, at 2500 RPM its well over 1/2 way and at idle it's around 1/3.
I keep checking the oil level and it's not moving - she's not a great oil burner in any case. The cooling liquid's still nice and clear - no foam.
Engine temp quickly gets to just below 1/2 way which is how it behaves normally, in hot or cold weather.
Last oil and filters change was around 2 months ago so I've done around 2,000 km on this set.
Is this a feature in hot weather.... or do you chaps think I need to look at renewing my AA membership...
Oh, Air con on or off dosn't make a s$$$$ of difference.
Thanks,
Joe
Thanks,
Joe
