just done a search, but it appears that so many parts of the tailgate assembly can fail, each thread describes a problem, or symptom unique to the poster!
all my tailgate tackle was hitherto ok..the first symptom of impending doom came when the cockpit switch failed to lower the window, but if done via the key, the interior switch would raise it..
that was a week ago..today, the window was lowered via the key, for the purposes of loading the rear with the usual tools, bags of rubble and step ladder that signify the beggining of the weekend..the unloading proceedure was equally undramatic and successfull, on both accassions the window was raised, with the key without complaint..
now t'bugger won't shift..up, nor down..tiss well and truely stuck..stick the key in, and it will not turn to the right..it will however turn to the left, with an acompaning click from a relay...i'm scuppered....
i've pulled of the rear panel, to reveal a black cover held with screws..i looked at it for several seconds..then made a cup of tea..can you fellas suggest a starting point? or is the realms of the expert? of which i am most definitely..........not.
