I,ve got a rattly noise from the head...ish area from startup till a little warmer ????then it goes away ... has anyone experenced a similar thin and what was it .............go gentle on me i,m fragile after last weekend
As you cannot exactly pinpoint the source/ say "then it goes away", dont know what you'll achieve by spannerwork, is it low on oil or due a change...Five thousand is top whack between oil changes and it is getting warmer (ambient temp) whether you believe it or not in uk at present time..
