toped up trans fluid in gearbox the other day,then set of to work about 30 milles away when i arived at work stoped car to pull into car space and no drive power at all so i have had her towed back to my home i havant changed the trans fluid since i got her 2 yrs back could this be the problem that it needs a total change?
will not move
Originally posted by tonys surftoped up trans fluid in gearbox the other day,then set of to work about 30 milles away when i arived at work stoped car to pull into car space and no drive power at all so i have had her towed back to my home i havant changed the trans fluid since i got her 2 yrs back could this be the problem that it needs a total change?
No, fluid will never degrade to the point where drive is suddenly lost as you are describing. Its either a valve or a mechanical problem with the selector. Does it not operate in any gear at all? if so its not trying to select them.
Al.I used to have a surf me!
If it was working before your topped it then you need first rule out things you've done, ie correct oil? or overfilled it.
Or it could just be a coincedence.
I'd drain it and refill first anyway.
Originally posted by tonys surftoped up trans fluid in gearbox the other day,then set of to work about 30 milles away when i arived at work stoped car to pull into car space and no drive power at all so i have had her towed back to my home i havant changed the trans fluid since i got her 2 yrs back could this be the problem that it needs a total change?4x4toys.co.uk - Keeping you on and off the road...
I've heard that overfilling produces foaming, but not seen it personally.Originally posted by scottpxOn a similar subject as Tonys Surf,Is it possible that overfilling the transmission gearbox will affect the gear changing on a 2.4 93 diesel model.4x4toys.co.uk - Keeping you on and off the road...
Check you haven't knocked the short gear lever into neutral, it should be pulled back into H2, or towards the drivers seat. Put transmission into 'Park' or 'Neutral' then move short lever towards you.
Originally posted by BUSHWHACKERCheck you haven't knocked the short gear lever into neutral, it should be pulled back into H2, or towards the drivers seat. Put transmission into 'Park' or 'Neutral' then move short lever towards you.
Doh...... I never thought of advising on that but you ARE QUITE RIGHT TO MENTION IT vINCE AS i BET THATS BEEN DONE BEFORE
Oooh Think i hit the caps lock there.....I used to have a surf me!
it as been giving me truble for about a week know, as i come to pull of i have needed that extra exeleration at start it rolling. so my frend told me to check fluid in trans box wich i did and added half a pint then set of for work and now i have to give it a min then try again then it goes again.Originally posted by phoebelalaNo, fluid will never degrade to the point where drive is suddenly lost as you are describing. Its either a valve or a mechanical problem with the selector. Does it not operate in any gear at all? if so its not trying to select them.
Al.
h2, on my 3rd gen is towards the dash ive had my surf for 2 yrs know and thank you for your helpOriginally posted by BUSHWHACKERCheck you haven't knocked the short gear lever into neutral, it should be pulled back into H2, or towards the drivers seat. Put transmission into 'Park' or 'Neutral' then move short lever towards you.
