mine seems to be bu*gered at the moment. i press the button, the light comes on in the dash, i press set (below 70mph, jap sytems wont function above), the light goes out....any ideas ?
cruise control
mine does this sometimes and will then only reset once the car has been turned off and started up again???????????????????,
i think it is the switch on the steering wheel, but you have to get to your speed and then only press the button once and take yr foot off the accelerator, and just see if the car slows slightly then it should pick up if not yup its buggered
mine wont work bellow 50 and above 70
mine has played up on a few occasions just the same as yours but when you switch of the ignition it resets and works again
i wonder if we could get them up to uk spec so they go over 70?????at the end of the day................ it gets dark
