hi, what size nib do i need for my grease gun to grease the prop shaft ? as the usual one that is on my gun seems to be to small !
Grease gun question ?
Re
Hi,
You need a grease gun with at least an 18mm nib to fit the nipples on the propshaft.
Remember to do the ball joints as well which you will need to fit nipples to in order to grease them.
I think it is a size of the nipples referred to as "M6" which I guess means Metric.
You will need nipples at right angles as well so make sure they are at 90 degrees.
In short, you need grease nipples size M6 and at right angles to be able to do the ball joints etc.
Later!
GaryLast edited by hellmett; 22 April 2006, 14:30.
I went to two local and very good motor factors today and neither of them had or have heard of an m6 size grease nipple or m6 size grease nipple adaptor for the grease gun ! i will try 1 more motor factors in the morning and see what they have, if all else fails i will take it into work and give it to the fitters to sort as i think they have bigger adapters to grease the caterpillar trucks .
