i thought i would have a bit of a lie down under my truck today and found i have two corroded pipes.
these pipes go into the truck aprox where the heater is in the rear,i think they feed the heater matrix?,is this correct?and if so is it a tricky job to replace them?,can you get the proper pipes from toyota dealership?
thanks alot
sean
1996 3.0 ssrx
thanks alot
sean
1996 3.0 ssrx
