Just become the proud owner of a 94 3.0L TD SSR-X, im going to be driving it to the french alps on friday & im after some advice on what (if anything) i should check or change before going. Obviously im going to service it with new oils & filters. Im also going to do a coolant change, any advice on changing the coolant would be appriciated, is there a drain plug in the block? whats the normal procedure for refilling the coolant?
Thanks
stuart
Thanks
stuart
