Hi i have a noise / vibration coming from my engine on idle up to 1500
rpm ish i thought it was the power steering pump so i have drained / flushed etc and the noise is still there, it appears to be coming from the power steering/ vucuum pump area , am i correct in saying that the brake vacuum pump and the power steering pump run from idler gears straight from the engine ? .if i load the engine ie turn the steeing wheel while stationary with the engine running the noise/ vibration dissapears, let go of the wheel and its back again, is there any ajustment of either the vac pump or power steering idler gears or do they wear? please help
Hannah
