Hello all, I wondered if anyone can tell me what the wire leading up underneath my drivers seat might be for, as my vehicle has no heated seat switch ???
Little Wire ??
Originally posted by RicksurfHello all, I wondered if anyone can tell me what the wire leading up underneath my drivers seat might be for, as my vehicle has no heated seat switch ???
I am fairly sure that all wiring on Surfs is the same on all models... They all have everything even if not fitted... i.e just cos you don't have heated seats doesn't mean you don't have heated seat wiring.. if you see where i'm coming from
of course i could be completely wrong!Paranoid? They're out to GET YOU!
Sounds good to me.....Will investegate further to see if I can have a warm bum on these cold morningsOriginally posted by joe112I am fairly sure that all wiring on Surfs is the same on all models... They all have everything even if not fitted... i.e just cos you don't have heated seats doesn't mean you don't have heated seat wiring.. if you see where i'm coming from
so your saying that thge light will go out if no ones sat in the drivers seat??? I'm sure mine comes on as soon as the engine starts even if noone is in the seat.... i.e. leaning in through the window starting after a repair or somthing!
I thought the sensor was in the seatbelt clipParanoid? They're out to GET YOU!
It is...Originally posted by joe112so your saying that thge light will go out if no ones sat in the drivers seat??? I'm sure mine comes on as soon as the engine starts even if noone is in the seat.... i.e. leaning in through the window starting after a repair or somthing!
I had to check that the light came on with no bum on the seat
Peter
I am not a number. I am a FREE MAN!
There's some truth in that. I had a warning light come on once telling me the rear tyre carrier wasn't latched shut. Which is odd as I'm an underslung.Originally posted by joe112I am fairly sure that all wiring on Surfs is the same on all models... They all have everything even if not fitted... i.e just cos you don't have heated seats doesn't mean you don't have heated seat wiring.. if you see where i'm coming from
your bum needs to be made of metal for the light sensor in the instrument cluster to go off....
j/k
the wire near underneath the driver seat is for the rear heater fan and also in that loom is the wire that connects into the seat belt buckle.
if the seat belt is not latched to the buckle when the car is on, the seat belt lamp will light up.
in Australia.. for compliance.. the buckle and the seat belt actually get replaced with australian standard seat belts and buckles which are way below the quality of the original toyota ones and also have no sensor in the buckles.
