does anyone now if there is a surf being broken near wigan i need a steering idler arm for mot
steering idler arm
Dismantle the arm. If the plastic bushes inside the arm are just worn then you can buy replacement ones from Milners for a few squid. If the shaft itself is all rusty and corroded (as a lot seem to be) then it's a complete new idler arm needed, but you'll notice the difference in handling so it's worth it.Originally posted by skettydoes anyone now if there is a surf being broken near wigan i need a steering idler arm for mot_________________
Nevillef
had already ordered it before you replied. i thought you neededmachinery to take out and compress new bushes into placeOriginally posted by laser_jock99Don't dismantle the old then- you might be gutted if it was just the £2 plastic bushes!
