Indicator connectors
  • Indicator connectors
    Hi People
    I am in need of a little help as my local toyota dealer is not very helpful.
    I posted a thread a little while ago explaining how some scumbag had just nicked my indicators and cut the wires. I am having real trouble getting the connectors for the indicators. Toyota dealers says they dont know if they can get them seperate ,because they dont have any part numbers.Or indead whether they can get them at all . They are even saying i might have to have a new front loom.
    Any help would be appreiciated!!!
    Thanks in advance Guys & Gals
    Mike
    I always work better wet .
    Its why I became a plumber!!!
    If you have replacement indicators, take them to your local s c r a p yard and ask them if you can snip a suitable bulb holder that will fit your indicators then just solder/ join the wires together to your trucks wiring. They probably won't even charge you for the bulb holders.
      You can come and snip mine for free if you want, or I'll post them.
        Hi Tony
        Thanks for the help i still havent got any joy .Even from a s****pie.
        Could you post them to me please and ill cover the postage and chuck in a free drink.
        I can either ring you with my address or pm you, but i think the pming gets a bit full
        cheers
        Mike
          Sidelights, Indicators [Front & Side] - Hope this helps ya!
          Gaz
            Originally posted by Mike66
            Hi Tony
            cheers
            Mike
            OK, give me a ring, look on my website below for number, under the garage section.
