Air-con
Could Someone Tell Me How To Work The Air-con. I Have Put Nob On Cold Setting Turned On To Full Setting And Then Pressed Air-con Button And Nothing Changes.
Suspension
What Should The Distance Be From The Centre Of The Rear Wheel Hub To The Bottom Of The Rear Wheel Arch Directly Above The Tyre.
My Back End Is Sagging Quite Bad. I Am After Some New Springs But Some I Have Seen Say They Will Give A 2 To 3" Lift And That I May Need Longer Brake Hoses Or Cables. If The Sagging Is More Than 3" And I Put Springs On Will This Lift The Back End Up To Its Original Position Thus Meaning I Will Not Need New Cables. Could Anyone Tell Me Some Places To Get Springs From So I Can Compare Prices And So On. All Help Greatly Apreceated
Suspension
