Roight fellas.....I have just got the trouble codes from my 3.0L
they are showing as 14 and 24....which is here:-
14
IGNITION SIGNAL--NO "IGF" SIGNAL TO ECU --IGNITER/IGNITER CIRCUIT
--IGNITER AND IGNITION COIL/CIRCUIT
--ECU
and
24
INTAKE AIR TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN INTAKE AIR TEMP. SIGNAL --INTAKE AIR TEMPERATURE CIRCUIT
--INTAKE AIR TEMPERATURE SENSOR
--ECU
as from here...
http://www.off-road.com/toyota/tech/codes/index.html
My question is ....what the hell does this mean..?????? HELP
Where do I look...what do I look for and how many gallons of petrol for it to burn efficiently..????
VINCE....VINCE....VINCE where are you......Can you sort these out????
Help very much appreciated....Darren
14
--ECU
and
24
--ECU
as from here...
