My new Surf - a 95 SSRX 3.0 I imported from Japan, when standing unladen on level ground, looks like it's got a pallet of bricks in the back. Is there any thing I can do to make it sit level?
Droopy Ass...
www.milneroffroad.com they do 20% uprated springs for £40 they will do what you wantOriginally posted by Paul WMy new Surf - a 95 SSRX 3.0 I imported from Japan, when standing unladen on level ground, looks like it's got a pallet of bricks in the back. Is there any thing I can do to make it sit level?https://www.facebook.com/groups/henpals/
Originally posted by BUSHWHACKERThe only way to get the back end up is to replace the springs.
£40 +vat per pair from Milners.
Sounds simple enough... Thanks, I'll look into that. Would I need standard or uprated springs?Paul
It needs more Chrome!
Thanks to both Bushwacker & Stormforce for the info. I'll check out Milners today. Wish I'd found this site months ago... Got more Surf info in last 4 hours than last months. Cheers LadsOriginally posted by BUSHWHACKERIf you do a bit of towing, then get the uprated ones. Otherwise standard springs will be fine.
Milners only seem to sell the uprated ones though.Paul
I take it these are a differant spec spring to the ones advertised on Roughtrax for £78.00+ (Part SU005)...? Or are Milners just cheaper?Paul
Not too sure, but I've got the Roughtrax springs. Sit the truck up nicely,with about a 1 1/2 to 2 inch lift. Stiffer springs, and a lift too! Bargain!Originally posted by Paul WI take it these are a differant spec spring to the ones advertised on Roughtrax for £78.00+ (Part SU005)...? Or are Milners just cheaper?It just does, OK?
ive got the milner springs on my truck it now sits totally level with the front, i was able to keep the hard soft button on suspension.
all i'd say to you mate is buy'em they made a hell of a difference to the way my car looks and handles alot better, i can put my trlailer on the back with 2 fat bikes on it and the suspension hardlys dives. get em bought £40 bargain.
Suspension switch
I don't seem to have a suspension button on my Surf. Are they standard, or is it a factory option?Originally posted by BIG Give got the milner springs on my truck it now sits totally level with the front, i was able to keep the hard soft button on suspension.
regards
Trev DowleCheers
Trev D.
