I have the 94 3.0 and around town it never overheats, but on hills and at higher speeds it does overheat as is well documented on this forum.
I want to add a transmission cooler, but I'm honestly a little confused about which one and where. There seem to be 2 sizes that might be appropriate. They are both the stack variety which are essentially the same in size but one is taller 5 1/2 x 11 x 3/4 (the short one) and the other is 7 3/4 x 11 x 3/4 (the taller one). Which one would you guys recommend
Check the website for pictures http://www.bulkpart.com/Merchant2/me...yden-transaver
Second part to this question. Where does it go? I have seen them mounted near the lower part of the radiator. See the following link if you need a visual clarification: http://www.yotasurf.co.uk/forums/sho...ight=Speedflow
but the transmission cooler websites suggest it go higher and up against the AC rad so the viscous fan can help cool it, which makes more sense especially if you are straining the transmissoin at low speeds where natural vehicle airflow would not affect the cooler.
Placement of the cooler may affect size. I'd love to see someone with at 94 3.0 that mounted it higher against the AC rad.
Thanks for your thoughts.
Ruaha
Ruaha
