I have just replaced the brakes on my surf. Only problem was, the first front wheel I took off, I assumed you had to unbolt the caliper housing. Wooooooooooops
fluid flying everywhere.
I have cleaned it all up, bled the vaves through all around and filled the resevoir back up.
should their still be a bit of sponge in the breaks??
Have I done any damage to the caliper housing?? I've tightened it back up and their doesn't seem to be any leaks.............
can anyone help??
thanks..............
can anyone help??
As long as you havn't pinched the o-ring!
