from what i have read the egr valve is different on newer surfs like mine kzn185's .so is the mod still worth doing on this model,has anyone with a newer surf done it ? i have seen the pics of previous threads and understand them,is the mod on newer surfs the same ,will someone kindly stick a pic on or expain any difference. my apolgies to all you seasoned surfers who get sick of the same type of questions.
egr mod (not again)
as far as i'm aware yes its worth doing on any vehicle with a egr valve fitted - it is done in the same way but not sure if the acutal valve is in the same placeOriginally posted by HYPERMONKEYfrom what i have read the egr valve is different on newer surfs like mine kzn185's .so is the mod still worth doing on this model,has anyone with a newer surf done it ? i have seen the pics of previous threads and understand them,is the mod on newer surfs the same ,will someone kindly stick a pic on or expain any difference. my apolgies to all you seasoned surfers who get sick of the same type of questions.Paranoid? They're out to GET YOU!
cheers for the replies guys,think ill leave it alone for nowOriginally posted by luckyProbably less value on the newer ones because the newer ones are elcetronic and work better, don't cause the performance decrease that the older ones cause, especially when they fail open.hey just got a new 30 td surf all the gadgets 1997 metallic black niceeeeeeeeee
