Originally posted by Morr
kzn185 2" lift questions
Originally posted by MorrThats as big as you can go even with the 2" lift, any wider will require changing the wheels or fitting spacers as the tyre will foul the upper wishbone on the slightest droop.
damn i was going to see if the 295/75 r16 would fit on my wheels - is that a definite ?? Ive been told that the 275/75 r26 wouldnt fit on the stock suspension but i was running them with no porblem.
regards,
alex
.Originally posted by _cj_damn i was going to see if the 295/75 r16 would fit on my wheels - is that a definite ?? Ive been told that the 275/75 r26 wouldnt fit on the stock suspension but i was running them with no porblem.
regards,
alex
Yep, on mine (2.5" lift & standard rims) the 285 BFG's were rubbing on the upper arm under the slighted droop, ie dips in the road etc. A set of 1/4" spacers cured it easily enough.
To clear the 295's you want, you'd really want to jump up to the bolt on spacers such as those sold by trackstore (plenty of other threads on here about 'em), 30mm thick IIRCMaurice
