Checked the oil level on the autobox the other day and found it to be a yucky black colour which I don't think is good so need to change it.
I have done a search and found references to sticking the oil cooler pipes into two seperate buckets, one with new oil and the other to catch the old oil while running the engine, I guess this then sucks the new oil up which in turn pushes the old oil out, assuming you get the pipes in the right buckets
These instructions seemed to refer to the second Gen gearbox, is it also the best method for the 3rd Gen as I believe it is a different or at least modified version and are there any more detailed instructions on changing this oil.
I want to get this right and not damage anything so would be very pleased to get some guidance.
These instructions seemed to refer to the second Gen gearbox, is it also the best method for the 3rd Gen as I believe it is a different or at least modified version and are there any more detailed instructions on changing this oil.I want to get this right and not damage anything so would be very pleased to get some guidance.
because if I start taking stuff off i'll have plenty of wee bolts left over when I get to put it back together...
