I've seen this crop up from time to time and not a really positive solution. Well the dreaded rattle started on mine about 2 months ago. It was loud at start up, standstill and slow speeds AAAAGH! It would ease if I pushed on the bonnet between the wiper blades and at first I couldn't find a damn thing loose.
It got worse and seemed to echo round the bulk head. So in a fit I went over everything and at last found the culprit.
Attached to the bulkhead by a 10mm bolt is the heater valve bracket and it was loose. Tightened it up but the noise was still there. Back to the bracket and this time found that the screws that hold the heater valve to the bracket were loose as well. Tightened everything and bingo...no rattles at all!
My guess is the loose bracket loosened the screws etc.
