Think I need to replace front bearings as squeeking and wheels judder when I brake hard - changed pads/discs
Confused by what I need
RoughTrax list all this:
Search
Seals
Main Hub seal behind wheel bearings
/index.php?doc=16&vid=214
Bearings
Inner Wheel bearing, larger of the two wheel bearings.
/index.php?doc=16&vid=218
Bearings
Outer Wheel bearing, smaller of the two wheel bearings
/index.php?doc=16&vid=219
Thrust washer
Stub Axle thrust Washer between wheel bearing and adjust nut on front hub.
/index.php?doc=16&vid=227
Seals
Outer halfshaft seal, fits between wheel bearing and shoe backing plate.
/index.php?doc=16&vid=233
Bearings
Rear Wheel bearing
/index.php?doc=16&vid=235
Half Shaft/ Bearing Retainer collar
Rear wheel bearing retaining collar. Fitted between the snap ring and rear wheel bearing. Press fit. We only sell the high grade "Heat shrunk" collar as per original fitment spec, afteral, this is what holds your rear wheel bearing/half shaft in place!
/index.php?doc=16&vid=241
Spigot bearing
Spigot bearing
/index.php?doc=16&vid=318
Cylinder Head New complete
Complete NEW Aluminium cylinder head casting with refurbished valves. All the valve clearances are preset by shimns, comes with new cam bearings and the cam shaft fitted. This head will minimise the length of time your vehicle is off the road as its "ready to fit". Profesionally remanufactured using the NEW casting this head also comes with a full 12 month warranty (subject to conditions). Fantastic value.
/index.php?doc=16&vid=555
But what do i ACTUALLY need (don't wanna get ripped off by garage if they supply parts) ?
Search
Seals
Bearings
Bearings
Thrust washer
Seals
Bearings
Rear Wheel bearing
Spigot bearing
Spigot bearing
