Was chuffed to discover tonight that the Fuel filter assembly on my UK 4runner is a heated system. There is a fuel heater relay in engine fuse box, a pair of wires going to water sensor on base of filter.
Also 2 pairs wire on top of filter, 2 go to heater system and 2 go to a vacum switch.
Edited: 6/9/05
Figured out the wiring now - heater relay works, and also fuel filter heater assembly gets hot if I bypass the vacuum switch.
Not sure when and how the vaccum switch comes on ??
anyone any ideas, does it sense thicker fuel i.e. cold diesel?
I might install a bypass switch so that I can bypass the vacuum switch and heat veg oil mixture up
will be usefull as i am running on more vegoil and heater will help make the veg flow better
Edited: 6/9/05
