Did it this morning because the truck was running like a dog with no revs or power and intermittent 'check engine' light.
I set aside a couple of hours as I'd never done one before. Had it done in all of ten minutes!
For info for others I found it very easy to do it as follows. The experts on here can point out any easier way or big goofs I may have made!
I found it hard to take out the plastic float switch / drain tap housing from the bottom of the filter in situ, so...
1) Undo the two fuel pipes and remove from the filter housing.
2) Undo the float switch connector.
3) undo the filter housing nuts on the bracket and remove filter assembly.
HOLD UPRIGHT until you have a handy receptacle for dealing with the manky diesel / chip fat / general sludge mix.
4) Change trousers for ones not drenched in diesel / chip fat / general sludge mix.
5) It's now easy to wrap a rag around the float switch / drain tap housing and undo anti-clockwise from the old filter.
6) See if the filter will remove by hand from the housing, find it wont, so either clamp it so you can get better purchase with your chose filter wrench, ot drop it over the stub bolts on the car and do it there. Remove filter. (Mine wasn't very tight at all, certainly not as tight as the oil filter!!!)
7) Marvel at the amount of **** that resides in your filter. Throw it away or save to show to your soon to be amazed friends.
8) Clean up the mating face of the filter housing and clean the gunk off the float switch, and fit the filter to the housing and the float switch the the filter.
9) Re-fit the whole assembly back from whence it came, pushing on and clamping the fuel pipes.
10) Prime the filter by pressing the plunger on the top of the filter housing until resistance can be felt, then press it some more for luck.
11) Start engine and go for a run, marvelling at how the truck will now rev freely and pull like a train.
12) Feel proud of yourself for saving a few quid in garage bills
PS. As this is the first chance for a week or so I've had to this, I wasn't sure whether the ECU had gone into sulk mode so I disconnected both batteries for half an hour and lobotomised it. Everything great now. Goes like a train!
