Full synth oil
  • Full synth oil
    Hey all,
    I'm about to embark on an oil change on my 3.0 and I have been told by several people that fully synthetic oil (5w/40) is the best oil for larger TD engines.
    Is this o.k or do I need a specific type of oil...???
    Darren
    synthetic is the best, but since its only in there for 5000 km, and they aint exactly race cars do you need the best? if it was one of these new fangled common rail things with a 18000 mile intervals, its the way forward, but i am using good old mineral... cos i'm a cheapskate.
    it's in me shed, mate.
      Originally posted by 30Surfer
      Hey all,
      Darren
      use 10w/40 [semi-synthetic] its good enough and cheaper. Seeing the oil changes are more frequent why waste your money!!
      Gaz
        i always spend a bit more on oil cos i'm a lazy git!... doesn't matter so mch if you leave it a bit longer between oil changes.
        go for magnatec gtd 10w/40
          I use the stuff my brother lets me have for £5.50 for 7.5L. Thats cheapo 10W/50 and is sold to garages for use in petrols and diesels. It's only there for 5K Kms.
          A question for the mechanically minded. What is different about these diesel engines with the huge service intervals? Is it to do with the filters?
          It's only a hobby!
            Oil change every 5k...oops i'm a muppet....I thought it was 12k...
            I've had it nearly 2yrs and I changed the oil and filters when I bought it...done nearly 13k and only now changed the oil.....I also want timing belt changed, it was changed at 40k and it's on 102k now but don't know who to trust in my area(Gwent, S.Wales)...any recommendations...???
              i bet it felt sweet after that oil change!!
                don't know how often truck have their oil changed cos they go in for a check every 6 weeks, but the oil only gets changed on a service.
                brand new they change the oil at 7000 miles, but after that it just seems to be every 6 months... so that's about 30,000 miles.
                they're like, 11-16litre engines
                  Trucks yeah after 6K they have oil changed because from new they are filled with running-in oil then every 21K...but thats how I get full-synth oil...cos it's recommended for trucks and it was a fitter for Merc that told me full-synth for larger TD's.
                    My old grandad..who has to be believed...reckons he gets more mpg with fully synthetic oils... no idea how that would work but he swears blind that he does... He has a LR Discovery.
                      Because of the price of fully synthetic oil, he just drives slower to save money on fuel.
                        Two years is way to long between oil changes regardles of mileage, a portion of your oil is designed to evaporate to protect the upper engine from corrosion and all but the very best synthetics are prone to oxidation and are slightly hydroscopic. So oil change every 6 months to a year for low miles depending on quality of oil.
                        For refrence I change mine every 3 months or so at roughly 6,000 mile 10,000Km intervals with no sign of ill effects, using mid priced oil. I've used the same rutine on other cars and put 1/4million miles on two with the engine still passing MOT emmisions even when evrything else was knackerd.
                          Synth or not
                          A fully synthetic motor oil is reckoned to be in better condition after 100,000 miles than your average mineral oil is after a few thousand. If you go fully synthetic I would see no real need to change every 5 thousand, I reckon you could safely double or even treble the interval
                          Bogus
                          Сви можемо
                            This might be of some help to you.
                            http://www.green-trust.org/2000/biofuel/lubrication.htm
                            Mart 870
                            Racing for Thomas
                              I might be wrong but I read it from another forum that full syn is too thin for older engine with some a fair amount of wear in it.
