95 ssrg 3.0td manual kzn130
lost drive on vehicle thought release bearing collapsed or centre of clutch plate had broken up, removed gearbox nightmare, found nothing wrong with clutch, checked gearbox ok. removed flywheel
sounds like some ones put a packet of tic tacs inside it(springs broke)fell over wen told how much replacement was.so do's any one know if u can convert a spring loaded flywheel to solid flywheel. milner sells solid flywheels with longer bolts & different clutch, but need to no if any one else as converted one & do's it run ok :
thanks
