Does anyone have the settings for the 97 3.0TD Surf 3rd Gen as mine was just set up using settings from the older LN130 model....
I'm not convinced of the similarity on the setup as they could not achieve the camber adjustment!
Here is what they thought it should be:
Caster 0.45' to 2.15' ????
Camber 0.15' to 1.45' ???? Are these correct for the KZN 185 ???
Toe -0.03' to 0.09' ????
My truck before was:
Left Right
Camber -0.46' -1.14' Tyres scrubbing on the outer edge
Toe -0.47' -0.18'
My truck after:
Left Right
Camber -0.07' -0.41'
Toe 0.02' -0.01'
As you can see the Camber (on maximum adjustment) could not achieve the figure expected.... ...and it still cost me 50 quid!
No obvious wear in the balljoints etc....are these the correct figures???
Drives a lot better though and there is no vague feeling in the centre anymore....i await the tyre scrubbing test!
Damon
Left Right
Toe -0.47' -0.18'
My truck after:
Left Right
Toe 0.02' -0.01'
Damon
