good morning all
have just compleated a rebuild, all back together except bash plate - in case of leaks! took the beast for a short spin ..lovely..however on the way back the engine warning light came on when over 1500 revs now on & off not particularly in line with anything. I have checked all the loom conections also the vac pipes and all appear to be OK, is there a likely cause, any sugestions welcome
I have done a search but can only find about ecu codes re 2.4 & 2.8's is mine the same, how do i get them to indicate etc??
Ta in advance
Tony
have just compleated a rebuild, all back together except bash plate - in case of leaks! took the beast for a short spin ..lovely..however on the way back the engine warning light came on when over 1500 revs now on & off not particularly in line with anything. I have checked all the loom conections also the vac pipes and all appear to be OK, is there a likely cause, any sugestions welcome I have done a search but can only find about ecu codes re 2.4 & 2.8's is mine the same, how do i get them to indicate etc??
Ta in advance
Tony
