Hi everyone
just want to make sure that i`ve got my idears right for when i fit my oil cooler and that i`ve got everything in the right order.I`ve done loads of searches but just want someone to say yes or no.
Out of transmission into cooler
Out of cooler into radiator
Out of radiator back to transmission?
Looking forward facing the surf, is the inlet on the radiator on the left and the exit on the right, and when the cooler arrives i`m hopeing it`ll have flow direction marked on it, if it does actually matter.
Just one more thing, with alot of heat exchangers and plate coolers you would have the flows going towards each other for maximum effect, i,e the outlet of the cooler would be plumbed in to the outlet of the radiator so the hotter oil would meet the cooler water first,but saying that is it not the case with the radiator.
Hope that makes sense
Thanks in advance
jack
Thanks in advance
jack
