I want to chop my exhaust off 2" behind the box and then connect it to some stainless steel flexi-pipe just can't find the stuff here in Africa, then I'd route the exhaust out the side of the vehicle.
Exhaust or Snorkel?
before going down the flexi-pipe route be sure its up to the task, i used flexi to go under the front prop when i lifted the truck. the engine vibrations destoyed the pipe very quickly! sounded good with the exhaust about a foot long.Originally posted by bundubasherI want to chop my exhaust off 2" behind the box and then connect it to some stainless steel flexi-pipe just can't find the stuff here in Africa, then I'd route the exhaust out the side of the vehicle.Diesel, like petrol only better
NOOriginally posted by TJGDid you have a Capri in the 70's, jacked up and sidepipes? As a schoolboy I only read "custom car" for the cars, honest mum.
but i wish I did!!!
Wasnt born till '83 mate.
Tim
Originally posted by Vagrant No2I would not run the pipes down the side as they would get crushed like the side steps when off road , unless you don't use off road. You could get some side pipes like the custom boys used in the 70's .
How about some really heavy duty metal tubing attached to the chassis down the side - dual use - exhaust pipes AND rock sliders all in one
No longer a Surf owner.
asda price
when they snap its time to look at how it is at the hangers and if it is not an old system go back and get it looked at at the garage that fited it but it sounds like it is tine to dip in to your asda pocket and give the moths a good airingS S R G is the only way to surf
scottish mud club member kerelawsurf
You're as bad as me! This thread is nearly 3 years old.Originally posted by jeff.fn02jwa View Postwhen they snap its time to look at how it is at the hangers and if it is not an old system go back and get it looked at at the garage that fited it but it sounds like it is tine to dip in to your asda pocket and give the moths a good airingDo you know that, with a 50 character limit, it's
