any body no the amount of water a 3,0ltr should hold please ,its just that i have had a new header tank and i want to see if there is much difference cheers
water level
Originally posted by mud-geany body no the amount of water a 3,0ltr should hold please ,its just that i have had a new header tank and i want to see if there is much difference cheers
My Radiator is perfect except the top header tank needs to be replaced.[IMG][URL=http://i11.photobucket.com/albums/a167/s
yes mate,the local rad supplier also repairs rads.there fitter removed the orignal top tank and made a newer and larger tank out of plate brass he used the orignial filler ,hose connection and brackets,it then gets resoldered and painted .it fitted a treat and looks the dogs ,if i get time tomorrow i`ll post a picture .he also flushed the rad and checked for blockages ,on inspection he said the rad is now better than new ,it also holds about a litre more water .a large portion of his work comes from local 4x4 dealers ,one of his customers even has a spare made up for several models,he would have supplied a new rad but said the rad was to good to ditch .DONT CHUCK IT fix it
Originally posted by mud-geyes mate,the local rad supplier also repairs rads.there fitter removed the orignal top tank and made a newer and larger tank out of plate brass he used the orignial filler ,hose connection and brackets,it then gets resoldered and painted .it fitted a treat and looks the dogs ,if i get time tomorrow i`ll post a picture .he also flushed the rad and checked for blockages ,on inspection he said the rad is now better than new ,it also holds about a litre more water .a large portion of his work comes from local 4x4 dealers ,one of his customers even has a spare made up for several models,he would have supplied a new rad but said the rad was to good to ditch .DONT CHUCK IT fix it[IMG][URL=http://i11.photobucket.com/albums/a167/s
Originally posted by mud-gehi mate ,hope these piccs are of use,the chaps name is john ,the company is kingston radiators of southampton phone number is 02380225959
I called them, and the first thing they said was ,"is it the top tamk", it appears that this seems to be a common fault, they seemed to be a friendly bunch, so i have taken my rad out and will courier it down to them, will keep you posted on how it goes, hopefully they can save me a great deal of dosh[IMG][URL=http://i11.photobucket.com/albums/a167/s
