I have a high-pitched squealing noise coming from the engine under load and at very hi revs offload. It seems to be completely throttle-position related and load related as I can get the noise in any gear, at any revs at any speed. I can even get the throttle set just right and make the noise come and go with the slightest movement of the pedal.
It’s not a fan belt noise and is constant with the throttle set pass a certain point. Don't think it’s the turbo as it’s only under load and not when free revving.
Just had the engine rebuilt after new head and 2 cylinders relined. Everything else sounds ok. Wife also says it used to do it before the rebuild but very intermittent - air con?
I think it could be:
1) Vacuum related split pipe etc?
2) EGR valve as I disabled it before the rebuild - poss. knackered EGR?
3) Air Con unit squealing - haven't had it re-gased yet so can't run the compressor.
4) Don't know?
Help please its driving me mad and I'm kind of worried that its something expensive and we go away with the caravan (1600kg) end of May.
4) Don't know?
