hi gang..surfers paranoia again probably, but i'll run this past you, see what you think..i was talking to a mate earlier, started the beast up, only for him to announce, "look, blue smoke".."what"! was my panic stricken reply..well, several starts later, all i'm seeing is the usual sooty black, turning to grey as it disperses..smells like fuel, as it always has done..trouble is, this guy is a mechanic, and he is adamant there is a blue haze on starting.
ok, so i did experience a drop in level which was a concearn, during the cold winter months, but have since put it down to expansion and contraction due to ambient temperature..i've since done an oil change, so am unable to assertain wether it was still "losing" oil from that origional level, although it certainly doesn't appear to be losing vast amounts, if any, at the moment.
thing is, the motor is a 3ltr lump, and very low, well about 50,000 miles indicated, even if the reading aint true, i doubt its done a great deal more anyway..so what have we got, rings, valve seals or turbo seals..well, i'm by no means an expert, but thinking it through, blue smoke on start would indicate something dripping down, then blowing through the system after firing, which to me, would indicate valves, right?...is this likely on a motor of such few miles?..i really cannot imagine a ring wear problem yet..
any input would be helpfull, although i'm not in too much of a tiswas about it just yet..it has got me wondering though, has anyone else noticed the blue smoke on starting with a warm engine, does anyone's rig require top-ups from time to time, even low milers and is there any other possible reasons for the haze, other than my mate being jealous or the reasons i outlined earlier?
Nil Illigitimi Carborundum
