How do I tell if I have an LSD?, hopefully without getting it filthy?
LSD............Man.
Method A: look for sticker on Diff saying LSDOriginally posted by TJGHow do I tell if I have an LSD?, hopefully without getting it filthy?
Method B: search on forum for how to read axle codes to reveal info from your data plateMaurice
..... or a knackered LSDOriginally posted by GamedawnMethod C: Jack up back axle and turn one wheel by hand. If other wheel turns in same direction it's an lsd, if it goes in the opposite direction it's an open diff.
Maurice
Damn! I was gonna write that!!!!Originally posted by Morr..... or a knackered LSD
I always thought the 'limited' on newer trucks was for the limited, but not sure now, as Linda's axle code ends with a 4 not 5, and the wheels turn like an open diff.4x4toys.co.uk - Keeping you on and off the road...
I have the same scenario....trying to deduce without opening up whether to put LSD or normal diff oil. Remember sticker on diff but had no writing on it..had wheels up on jack stands and turned the wheels and they went opposited way and vin plate ends in 4Gaz
