Starter Motor Problems
  • Starter Motor Problems
    I have a 3.0 Tdi SSR-X which, every so often, I have a problem starting - I turn the Key and all that happens is an audible Click, after a couple of more attempts it then starts - obviously this is related to the Starter Motor. it's not every day - usually just when you're in a Hurry!! Has anyone else experienced this Problem? and if so, what was the Diagnosis and Remedy? Cheers!
    Better to be in Cumulonimbus than Cumulogranite
    Try a search, this is most likely the starter contacts are burning out, the p/n's and how to change em have been posted a few times before.
    Maurice
      Thanks for tha Morr, had a look around the site and founds lots of useful Info with regards to Starter Motor Problem. However, do you have to go to a Toyota Dealer for the replacement kits? I see that Rough Trax do a 3.0 Starter Motor Repair Kit for £19.90 (£33.07 inc p/p), as well as a Starter Motor Bush Ring for £45.00 (£85.95 for both inc p/p) - are these prices comparable with a Toyota Dealer? and would the Repair Kit cover the burnt out Contacts?
        I've never had to do this job myself, so I'm not certain as to the best source, I know some of the prior posts did quote prices from Toyota, and as I recall they were fairly reasonable. If you can't find enough info on the prior posts, I'm sure some of the others that have actually done this will chip in with some info.
        Also as the p/n's have been quoted, you could always ring toyota and get a price.
        Maurice
          I did the job about 6 months ago and from memory Toyota charged about £75 for all those bits, will look for the invoice.
            T28226-54320 Starter Kit £5.78
            T28226-54220 Starter Kit £9.39
            T28235-17030 Plunger Switch £14.92
            All plus vat, This is for the KZN185.
            I was wrong on the total price in the last post as I did buy other parts with it.
              Click here for the Start Kit and pricing. I purchased from Toyota using chassis details
              KNZ130
              http://www.yotasurf.co.uk/forums/sho...5&postcount=10
              For other Technical-Mechanical info look at the thread below
              http://www.yotasurf.co.uk/forums/showthread.php?t=62
              Gaz
                Hi chaps
                I've had a similar problem to this this morning. Turn the key and just a click sound. The RAC came out and said the starter was shot. Do you think this is the case or is it just the starter contacts burnt out?
                EDIT: Ive just noticed another thread on here talking about the kit to fix this from 'ROUGH TRAX' but the link to that site is dead - anyone know if they are still about?
                  Originally posted by Fox
                  Hi chaps
                  Try www.toyotasurf.com
                  Maurice
                    Hi chaps
                    Almost certainly just the contacts. I did the job a while ago and it's quite easy. Hardest thing is getting the motor out of the engine bay.
                    use the link above for part no's (I used The Toyota parts) or get the roughtrax kit
                    http://www.toyotahilux.com/index.php...5&category=152
                    Fieldsy did a very good write up on PDF format but it's too large to attach. drop me an e-mail addy and i'll send it on.
                    mudnstuff.me.uk
                      Write-up
                      heres the link to the write-up
                      http://www.afm15.dial.pipex.com/sur...eplacements.pdf
                      Gaz
                        [QUOTE=andy]T28226-54320 Starter Kit £5.78
                        I would agree with andy thats about what i paid and they posted them tome free from toyota
                          I ordered the required parts at my local Toyota Dealer over the phone 3 days ago. There are now in and I'm on my way to pick them up today. The cost is as follows (including VAT):
                          28226-54320 £8.18
                          28226-54220 £8.18
                          28235-17030 £16.59
                          Total Cost is £32.95 - Funny how all dealers seem to charge a little differently!
                            I did this job last weekend and after the hassle of getting the starter out (its the size and weight of a small engine!) the job is a doddle. I got the bits from roughtrax and followed a tutorial I found on the site. I did only buy the contact kits (from roughtrax) but would recommend you buy the plunger as well. One of my contacts was almost gone, but I got away with spinning the plunger in a drill and running a file over it until it was clean and smooth. Starts like a good 'un now, and the starter spins a lot faster!
                              Oh, and wouldn't bother with bits for the starter motor itself. Just do the solenoid contacts, I bet you a banana that will sort it out!
