I have just bought my first Surf. Do they have head light trimmers especially for towing. Pardon the suggestion but I am always getting flashed at for my beams seem to be blinding oncoming drivers
head light trimming
They're probably flashing you cos they admire your Surf so much!Originally posted by TommyBI have just bought my first Surf. Do they have head light trimmers especially for towing. Pardon the suggestion but I am always getting flashed at for my beams seem to be blinding oncoming drivers
In the MK2 Surf 1989-94 the only way to adjust is get the bonnet up and adjust manually (towing is not common practice in Japan). If in doubt have them adjusted at a garage.
Nevillef
yeah, you need to point them down a little, only the UK 4Runner have adjustable headlights. If you can find one in a breakers it could be retro fitted, but only if you have a flush headlight model, If you have pickup style headlights, UK pickups may have them, and would be an eaiser find over here.
grin, wave, and say " thank you, yes my car is far superior to yours in every way"Originally posted by TommyBI have just bought my first Surf. Do they have head light trimmers especially for towing. Pardon the suggestion but I am always getting flashed at for my beams seem to be blinding oncoming drivers
As already stated you could have the saggy a**e syndrome. I found this with mine after outting the trailer on the back...The birds in the trees thought is was daytime all the time.
Measure from the centr of the hub to the underside of the wheelarch without the trailer attached and if below 14-15" if correctly rembered then you have butt sag.Last edited by Gizmo; 10 April 2005, 14:13.Gaz
Right - so thats a limited slip diff AND adjustable headlights I need from a 4Runner now. OK - where do I find a dead 4Runner?Originally posted by TonyN
Kev
