Should I replace my Pistons at the Same time as my Rings?
  • Should I replace my Pistons at the Same time as my Rings?
    Hi everyone, I currently rebuilding parts of my 1kz-te diesel engine with 220K km on it, in my Hilux surf and I have to replace the rings on my pistons because a couple are bad!
    Should I replace just the ring or should I replace the pistons and the rings at the same time? There is only a $150 different in price, so cost is not a factor here.
    Thank you for your input in advance!
    you are in Canada, if its not much difference i would change them too
      Hi BudWeiser, yes I'm in Canada and the difference isn't that big, so i think ill change both! Thanks for the help
