Hi does anyone know the specs and size of the steel pipes that run from auto transmission to oil cooler. Both mine are leeking and need replacing.
Metal transition to oil cooler pipes
Don't know size but part numbers are here -
https://jp-carparts.com/toyota/partl...er=toyota&type =671160&cartype=4&fig=3514
OK thanks, need it urgently so haven't got time to order from Toyota I will take it apart tomorrow and measure it. I will post sizes incase anyone wants them in the future. £35 pounds for flaring tool from machine mart and a few pounds for new stainless pipe probably cheaper than Toyota parts.
Yes will only use stainless if I can find soft wall, trying to find if thick wall copper is OK because could do with replacing fuel lines as well. But not sure if diesel or oil will be OK in it have found some copper that is for heating oil so think it would be OK.
