Hello guys I am a proud owner of a 95 3.0td surf I've owned it now for 2years with no problems spent a small fortune on it replaced all components to do with the cooling system runs great ,until the other day started it up and it started running rough with white smoke then cleared up after a couple of minutes,done my research and started with glow plugs took the old ones out tested them and they were knackered,fitted news ones all was good took it out for a spin all fine .The next day before going out again checked the coolant the rad was down and it filled the expansion bottle up with a slight oily residue ,so all points to head or gasket I am waiting on a sniff test to confirm this my question is are the new amc heads a upgrade to the original Toyota heads and how has it cracked with out over heating well not since ive owned it thanks
also ive try to get hold of stevo at the engine co and seems there not there any more
