Hey Guys,
have ghosted the forum to try and find as much info as i could, have found some threads with similar symptoms and have carried out checks but its time to ask the forum. so first post!
have a 1993 Toyota Surf ssrx kzn130 with the 1kzte auto transmission.
I was driving home and was cruising the truck up hill, - (wasn't giving it beans) and the engine just died. no splutter just as if i turned off the truck. the fuel light was on and assumed maybe i had run out of fuel
i selected neutral and tried to start the truck and had a flat battery symptom - engine struggling to turn over. - a strange fault for a potential Out Of Fuel fault.
i managed to coast it pretty much all the way home - thank god for decent wheel bearings and no traffic.
i tried turning the engine over again, with the bonnet open and the engine gave the same symptom with the engine locking up. - could see the aux belts rocking as the engine tried to turn over.
list of things i have done since this happened.
Refueled
replaced Fuel Filter.
Blocked off and removed EGR- egr was loose at the threaded part.
Charged Batteries,
cleaned battery terminals,
replaced all battery connections
replaced both negative pole earth cables - from batt neg to engine block.
checked ecu, looks to have been repaired previously, - any help to tell me what to look for or how to check capacitors would be great.
when i start the truck now takes a while to start ,then will run for about 15-20 seconds and cut out - dead stop sometimes giving the slow turn over when restarting.
i have loosened the alternator belts in case the alternator was seizing, but im starting to loose my patience ahha.
one other thing, found the earth from under the inlet on the back of the engine, have this connected to the inlet manifold - assumed it would go onto the engine as its part of the loom.
any help greatly appreciated, me and the GF love the truck. but currently having to drive around in a combo van :/
