Hi, my Toyota shares the same engine as yours. I am having an issue sourcing new belts for my engine. I am wanting to replace the fan belt, aircon belt. My local parts shop has supplied me with a toothed belt that they state is correct for my vehicle, KCH40 chassis. I have spoken to people in the know about the Regius and I am told that I should be using the toothed belts too. Presently on my van I have ribbed belts (track/lines) for both belts. I cannot see a part number on either belt. My mechanic friend also thinks that I should replace the belts with the same ribbed belts. I am at a loss, can anyone help with part numbers or have you any information that may be of help. Have you had similar problems. Thanks in advance for any helpful responses. Rod.
Toyota Hiace Regius 3Ltr TD
Have a look on https://jp-carparts.com/toyota/carty...ta&type=712110, they list several KCH40 variants, so you should be able to grab the part numbers from there.https://galooph.com
