Evening,
I'm hoping to pick up a Surf this weekend, and fix an issue with
It's a 3l diesel Gen 2 SSRX.
There is mixing of oil into the coolant, presumably engine oil but he does note that no creamy residue is on the oil filler cap. His mechanic friend thinks it is a broken oil cooler (which transfers the heat between radiator and engine oil?)
Does this sound plausible, I.e. he's not trying to get rid of a car with a cracked block or head?
And are there any things I can do to double check his theory, and do you think it's safe for a 5 mile journey home before I get down to fixing it? He says it's never overheated.
Thanks.
Thanks.
