So I changed my clutch and flywheel recently, and it seems like the throw out bearing has been constantly engaged since. It squeals when the clutch is disengaged, and if I get underneath and push the lever and clutch slave rod in a little it stops squealing. I've adjusted the clutch pedal but that hasn't fixed it. The slave cylinder rod is entirely cylindrical so doesn't seem to be adjustable. Is this the case or is there some way of shortening it? If not is there any other way to keep the throw out bearing disengaged when the clutch is out?
